I’ve had a few like this in the past and it takes ages for Qobuz to even take a look at the file normally weeks (as others have found on the forum).
Then again a common comment on the forum they “don’t” do refunds and if and when they do respond they will offer you a replacement track - any track you want but not the faulty track.
Qobuz are great when it goes well but if there is a problem then it takes an age to resolve.
With my repair I had it sorted in minutes. Bit like the vinyl guys on here that use a vinyl cleaning machine.
Yes the streamed version and all the other file versions Flac, Wav, AIFF and ALAC all have the same glitch on just that one track at the same time interval.
All the other tracks play perfectly. Just like a record with a scratch but in the case of digital it’s repairable.
