Diy record cable
Hello
I would like to build cable for cassette deck.
I have a piece of old 4 cable chord crysalis. I know how rca to din is builded ( red white and the shield as ground. The question is the din to rca, what is the ground cable, the same shielding cable or how should it be done?
Regards Hannu
Same way, just different signal pins on the DIN connector.
Look in any Naim manual and you’ll see how to wire up the din plug.
Remember this is looking at the socket, not at the end of the plug which will be the same but mirror image.
Clockwise from the right pin;
Ch1, ch2, gnd, ch2 out, ch1 out
Thanks!
Hannu
