OK, here we go…
PREAMP: NAC72
2 CHANNEL AMP: NAP250
3 CHANNEL AMP: NAPv175
DVD/SACD PLAYER: Magnetar UDP900
TUNER: NAT03
I am afraid I already know the answer to these questions…
QUESTION #1: I wanted SACD, DVD-A 5.1 channel audio and 5.1 DVD and TV audio. So I bought the above components.
I hooked up the DVD/SACD player to the CD input of the 72. There are RCA outputs from the DVD/SACD player that I run to the amplifiers. Here is a picture of the back panel for reference:
There are no INPUTS on this device to take the sound from the TV to the UDP900 to send to the amplifiers. So I would need a decoder to make this happen. Correct?
QUESTION #2: While hooking up the NAPv175 to the DVD player, and running the “sound check” program via the DVD player, the speakers reveal another problem…Unequal volume. The satellites are LOUD. I suppose I could get inline RCA attenuators. Would anyone have a guess as to what decibel level? Or would a good decoder have independent volume adjustments for all the speakers, including the satellite speakers?
