I would be very grateful if anyone can advise on Turntable connections to Nait XS3.
I have a Clearaudio Concept with Trichord Dino Mk3/Dino plus. The turntable RCA lead includes a Ground cable to the Trichord Phono Stage. Should I have a RCA lead with Ground cable from the Trichord to the XS3 (i.e to Ground Post on XS3).
I have no other Naim products / Source connected to the XS3.
It may well be down to the interconnect you are using between the Trichord Dino and the NAIT. However, it’s well worth experimenting here as you’re basically looking for least noise/hum. Also try disconnecting the arm ground lead completely (keep the volume down just in case!) and also trying a direct connection to the XS3, as well as a connection from Dino to XS. Also try different i/cs. Are you going RCA Phono to DIN (recommended)?
