Downloading purchased material from Qobuz
Apologies if previously discussed. I couldn’t find anything relevant on a search.
My Unitiserve has recently packed up - hard drive I think - so I’ve started to re-download purchased albums from Qobuz. I do have a backup on a Synology but thought this would be easier.
On the Qobuz app, iPhone and iPad - no problems and all 65 items download. On the website only 7 items show and some of those cannot be re-download because of licensing restrictions. Qobuz AI help suggests this may be due to a recent problem at their end and things need to resync.
Anyone else encountered this?
Why do you need to re-download anything if you already have it on your Synology?
Downloading music within the Qobuz app is completely separate from purchasing downloads from their download store. The former is covered by your subscription and can only be accessed from within the app. The latter allows you to store and play music anywhere.
I don’t. I just thought it would be easier than setting up the Synology, currently in the loft.
What isn’t clear is why differing purchase numbers are showing on different devices.
I don’t have a subscription.
In the app, you will see all the albums you’ve bought and downloaded ie the 65.
Due to licensing, some albums you’ve bought and previously downloaded will no longer be available to download as of now.
As the Serve has died, how do you plan to listen to your downloads? The easiest would be to put Asset on the synology and play from there. Synology does have its own upnp server, which you could use, though it’s not as good as Asset.
Setting up the Synology simply means logging into it and turning on the server which should take you about 2 minutes.
The point I’ve been trying to make is that all purchases are available for download on the app, without restriction.
On the website only a few purchases are visible and some of them have licensing restrictions.
Why the difference?
Most are on Tidal. For those that aren’t I’ll use Airplay to a Mu-so2. Or headphones + iPhone. Too much to listen to anyway.
If you go to your account in the Qobuz site, you find all your purchases albums and you can download them again indefinitely.
Thanks for all replies. I’m an idiot. I hadn’t spotted a ‘next page’ indicator on the website. All downloads visible.
Well, luckily in this case you were ‘an idiot’… If not there would have been a genuine issue :wink:
