On the pre loved market, when documents are sometimes lost in time, is there any way to see if a power supply has had a DR upgrade?
There will be a sticker on the back of the unit.
If this doesn’t reassure you then a quick phone call to Naim will confirm if the unit has had a DR upgrade. Just be aware that if the upgrade was done overseas by the distributor the records at Naim HQ don’t get updated.
Thank you, I was indeed hoping for a sticker, great.
Also
As a very last resort… your dealer can inspect inside the unit and see if the DR upgrade has been done
