Qobuz mentioned months ago they were planning to have DSD as a download option late 2018 - I can’t see this has happened as yet.
Following on from the Music on Special Offer thread where there is mention of Carmen Gomes recordings in DXD/DSD, I’m wondering about getting a DSD file to try out.
Now from what I can see the Uniti and newer Classic streamers are limited to DSD 64/128
Nova:
WAV - up to 32bits/384kHz
FLAC and AIFF - up to 24bit/384kHz
ALAC (Apple Lossless) - up to 24bit/384kHz
MP3 - up to 48kHz, 320kbit (16 bit)
AAC - up to 48kHz, 320kbit (16 bit)
OGG and WMA - up to 48kHz (16 bit)
DSD - 64 and 128Fs
Notes: Gapless playback supported on all formats. All formats to 384kHz maximum over wireless network.
NDX 2:
FLAC and AIFF - up to 24bit/384Hz
ALAC (Apple Lossless) - up to 24bit/384Hz
DSD - 64 and 128Fs
M4A - up to 48kHz, 320kbit (16 bit)
Note: Gapless playback supported on all formats.
(Didn’t realise the Nova did not support lossy M4A.)
I’d be interested to know who buys DSD (or DXD files) as downloads, and if so where from (especially UK members as we may be limited to certain stores without VPNs etc).
Also what format - if the current streamers only support up to DSD 128, presumably conversion would be needed to play higher rate ones or DXDs.
I suspect I could buy higher rate DSD files and playback via Roon quite easily. Is there any software that allows easy downsampling of the files to DSD 64 or 128 to serve directly?
Also, I suspect some NAS devices may handle DSD but unlikely that Twonky on my old WD NAS will.
I guess if purchasing DSD/DXD you’d want to go for the best available quality, but current hardware limitations will affect direct compatibility without using software at some stage to present in a suitable format to the streamers.
Perhaps converting to formats supporting up to 24 bit/384 kHz might help???
I need to figure out what DSD 64/128 equate to in 24 bit equivalents.
