As an Electronics Eng. (retired) I was taught to switch on from source to end in order.The rationale being that you do not want to leave a high impedance input “floating” while the source’s output may be all over the place during power up. However, that lesson was nearly fifty years ago - OTOH, stuff one learns in “one’s yoof” does tend to stick.
If the Digital supply powers the output mute relays then you want Analogue on first to get stable then the Digital. Generally Digital has its own logic system to associated, with timers - Analogue systems use RC timers to give delays.
I have no idea what Naim do inside other than it all works however you power it on. I used to design and build electronic equipment for work and and have designed and built DACs for my own and friends use, so I also do know something of how all these things work.
Generally you want the Analogue system up and sitting ready before it gets presented internally with a signal or has non-stable output sent to your Pre. Digital is either ready working or not so is safer.
I switch my 555PSs on one at a time. It’s a habit I developed in the days when Naim equipment had more of a tendency to blow fuses on switch on. Turning on everything in turn allowed me to check that each box had started. Only my 500 still has this tendency and it is thankfully occasional.
I have never seen a simultaneous switch on recommended by Naim in any manual or article. If it was a preferred or recommended procedure, Naim would say so. There is more of a potential to trip a switch if several boxes start drawing at the same time.
Just for the record, what ORDER do you switch the power supplies on?
Ie analogue (burndy socket 2) first, or
Digital (burndy socket 1) first?
Or, perhaps, either!
Everyone is confident that the order does not matter.
However, it has been interesting reading the suggestions as to why one might be slightly better than the other.
Thanks to everyone for the help,
It’s is much appreciated.
My power on order is:
552PS (the 552 takes up to 30s to initialise so draws immediately but does not become operational).
555PS analogue.
555PS digital.
500PS.
These are stacked upwards, so I just push the bottom button, then work upwards.
So far as I know it makes no difference in which order they are pressed, although I was advised to turn on the 500 last. I remember that when the dealer last tore it down and rebuilt it, we discussed which box should go where on the rack for the best sound performance. We wanted the 552PS as far away as possible from the 552, and the 555PS analogue further away from the ND555 than the 555PS digital. Putting the 500PS one shelf under the 500 made no difference. I only have space for one stack, so this was considered the most optimised order for the space available.
The switch on sequence just arose out of the stacking order. Because I was advised to turn on the 500 last, I go up from the bottom. Powering up and down is rare. It’s been necessary of late because of thunderstorms and occasional flutters and brief on/off cycles in the mains supply, which can blow equipment fuses - we have spares. The mains has now been resolved.
Switching on from source to pre to power amp is in the manual. It prevents unnecessary thump sounds from the speakers if nothing else. Interestingly it is the power supply manual that is most explicit:
