Hi all,
For those running the above, which values did you settle on for resistive and capacitive plugs? Many thanks.
I believe 453Ω and no cap plug is the popular choice for Dynavectors. I had a 17D3 and used 470Ω with 470pF, when I borrowed a 453Ω plug I preferred my existing choice but the 17D isn’t your typical Dynavector.
453R and no capacitance for the MC Dynavectors for sure. That’s what I use for XX-2 Mk 2.
Yep, 453 and 0, that is what i use for XV1t and XX2
