Apparently, the Dynaudio Confidence C1s are hungry for power. Does anyone know if a NAP250DR will drive them well?
Thanks!
Thanks!
It will drive them, but of cos, more power is better .
A 250DR will drive the C1s and sound pretty good. I have C2 Platinum and started with a 250DR driving them. They sounded great that way. However, I upgraded to a 300DR and that was a revelation. It’s as if I did a major speaker upgrade. Bass response and overall control improved a lot, and they sound much better at low/moderate volume than they did with the 250DR.
I think you’ll be fine if you pair the C1s with a 250DR, but a 300DR will really make them shine.
