I acquired my CDX2 (early version) modded to be digital out - this version doesn’t have a switch to go between the two. Is there anyway I can go back to Analogue out???
No, unfortunately.
Thanks. Well that’s a drag…
Yes, get a DAC.
Yes, using a Chord Hugo TT but was feeling it was sounding a bit ‘lifeless’ so looking how to change things up
Just experiment with other dacs. Dont have to be expensive. The Naim makes a good transport.
You could try the obvious: nDAC. That’s a classic combo.
Roger
