External USB CD drive & Uniti Atom
@Richard.Dane
Please, if you have a moment, would you clarify something for me.
I read a couple of reviews that mentioned one could connect a USB CD/DVD ext drive to the Atom / Nova and subsequently rip your CD’s to a USB HDD/SSD or NAS. I’ve not seen any menu or function that supports that, so NOT true, correct?
Many thanks in advance.
atb, Buddy
Bud, I think that’s something that was mooted in pre-production as a possibility, but in the end it was decided against doing that as it added extra complication, so was not part of the final specification. It’s easy enough to rip using a computer onto an external hard drive or NAS.
Appreciate it, thank you!
Indeed is easy enough with a mac/pc…
Thanks again
