“Toggle” means to switch on & off or off & on. Do you mean set the mute button to mute or set to un-mute ??
Anyhow I’ve tried all possible combo’s on my Supernait & it makes no difference;
Maybe PCB track layout or that the Record bank outputs are buffered.
Whatever, happy to hear its a bonus for 282 owners
I checked it yesterday on my 552 and couldn’t detect any difference. However, I have always muted the record line when not in use and selected an unused input on that side too. I used to do that when I owned an 82 and 52 too.
Anything that draws more current from the power supply will be detrimetal to SQ.
Muting the record bank de-energises the relay coils & thus draws less current.
This is the logic applied in switching the display illumination off, removing unused phono/tape buffer cards etc.
I saw a Gillan gig in about 1980 and through ringing ears heard it being mentioned on Thames News the next day as having been so loud that the front row were in danger of hearing damage within 10 minutes, luckily I was in the middle rows. And then there was the Hawkwind/Motörhead double bill at Brixton Academy…
OK - so mute the Recording row, but which button furthest away? Recording row? If you do that on the Playback row you potentially change source do you not?
