Level 10 if its anything like my past cats ![]()
I work with a lot of people up at lever 8 and even 9, but most have missed out the other levels.
Cat goes to eleven.
Be interesting to see 2025 ![]()
Martin
I’m not sure this qualifies … The Holotypic Occlupanid Research Group (HORG) researches and phylogenetically classifies plastic clips from supermarket packs of bread.
Water, air (oxygen, nitrogen…). Hmm
Point taken, but you can’t make much out of water or atmospheric gases alone. What’s in a computer or HiFi?
Staying alive is more critical than computers or HiFi!
So you can exist on water and atmospheric gases alone. Enjoy your life!
Without those you die quite quickly or fairly quickly…
So without those everything else soon becomes irrelevant.
Priorities.
I don’t disagree with anything you say. But just ‘staying alive’ is not much fun. Your profile says you were a designer of scientific instruments and computer systems. I assume you used materials other than water and gases in those.
In any case if feel this discussion is futile so will cease our dialogue now. I will return to focus on music now.
Cheers!!
Am I missing something, this isn’t anywhere’s close to being accurate? The portion that covers most of Ontario Canada, you can fit over 4 of the UK just in Ontario alone. That area would probably be a 30+hr drive from one end to the other ![]()
