I was gone from home for 4 days. When I got back, it was written “Fault 35” on the screen of my ND5 XS. I rebooted it and it is now working fine. Has anybody seen this fault before? Is it just a temporary glitch, or could it be a sign of some bigger problem?
It has been working fine since the reboot, so I am hoping it was just a temporary glitch.
Sorry none of us could help you but that fault code isn’t one that is familiar. Naim’s Standard guidance says reboot a unit showing a fault code and if it persists then contact Naim support for advice.
Fault 35 is when the system attempts to talk to the DSP. But fails to get a reply.
Based on when the unit is in idle there are no comms to the DSP so something happened while you were away to make it talk. I suspect there may of been a brief power cut / mains disturbance and the product rebooted and then had a very low input mains as the DSP was being configured at startup.
