I sold my NAP 200 recently and the buyer heard a loud noise from his speakers. He has it connected to an Uniti (2).
I never used the standard Snaic (used an aftermarket one between NAC 272 and NAP 200.
Is it normal for the bit of copper seen on the picture to stick out? And could it have caused the loud noise?
And can the Nap 200 be connected to the Uniti without further settings?
Are you talking about a snaic (which includes connection for power) or an interconnect (signal only)? Your buyer should not be using a snaic.
What is your buyer’s uniti? Superuniti, unitilite or a new platform uniti (atom,star,nova)?
With a NAP 200 comes a Snaic 4 I believe?
When I bought the NAP 200 there wasn’t one in the box and it didn’t matter because I used it with a Unitiqute 2.
(I sold the NAP 200 and bought a 250 along with the Snaic 4 assuming it was the original part missing in the first place)
If a bit of copper sticks out, I would assume the snaic 4-4 is broken. I believe (not sure!) the din sockets provide grounding too so in worse case the signal or 24v connection was connected to the ground.
