Hi all can someone tell me how to hook up a headphone amplifier like fiio k4 pro to the back of the Supernait2. Many thanks
Hi-
You will need a “tape out” equipped 5 PIN DIN cable and you can use either the HDD or the AV input, both of which are equipped with tape output pins among the DINs on their inputs. Unfortunately, you may have hoped for an easier solution which you could use today, but at least you can get there one of these days.
Bruce
Blimey Bruce I wish I’d never asked now.I am struggling but there’s hope. Many thanks John
