Just measured mine - approx measured top - (inner rear corner - outer rear corner) inches:
RH Speaker: 27, 28
LH Speaker: 27.75, 28.75
So the speakers are towed-in an inch.
They are (approx) 2.5m apart (measured from facing sides) and each 1.3m from wall (measure facing side to wall).
So apart from using both Imperial and Metric measurements to keep you on your toes - that is how I have had mine for years.
Don’t know if I deliberately moved one speaker a bit (3/4 inch) more out - probably just ended-up that way and I liked the result so left it.
When setting-up key things were to level them so equal pressure on all spikes - if you use Fraim Chips under then none should rotate easy to touch and all feel solid. When bad ‘off’ it sounds ‘tubey’ with more resonance.
Then ensure the speaker is perfect horizontal and vertical (unless you like a funky-bass).
Tighten spikes all the same tightness and then leave alone - too loose and fast but brash - too loose and plodding bass bloom.
All done correct and wonderful - you know when it the ‘there’.
Then every few years check the torque for the other bolts with a proper torque driver and definitely never by hand; too tight is awful, uneven is even more awful - all the same and correct torque is wonderful.
Naim provide a torque chart. Mine sound best at (with my torque driver):
Bass Drivers: 2.925 nM (spec is 3 nM)
BMR surround: 1.97 nM (spec is 2 nM)
These are what my Driver says (another driver may have different calibration) - what I’m really saying is that more is not better - you can lose fine-detail and get a brash edgy sound. I adjust - listen - try bit more - bit less and settle on what delivered the most musical insight and best timing micro and macro-level.
With the correct tool first loosen a bit - then tighten; I found beginning at one bolt and working clockwise around the driver to do all sounded best.
This is as opposed to ‘cross-tightening’ side to side technique (which is recommended) - I tried - it was rubbish compared to in sequence. I think cross-tightening is good for initial assembly but not when the speaker is well-settled and seated.
I mention all this as the S800 when set-up really sings and is akin to a musical instrument to tune it up when installing to get it to sing.
You know when it is doing this when you are forgetting the speaker and distracted by the music.
I’ve had to do this once after 6 months of first install - and checked it again after 4 years and it did not really need it. Just check it every 5 years or so and only if you think it is off. Mine have stayed right for 8 years or thereabouts.
DB.
