Fixed unitiqute 2 screen
Haven’t posted in a while, I bought a unitiqute 2 quite a while ago with with a burned out screen, I bought a replacement (Chinese) and just finally! Got around to swapping it out, it wasn’t too hard.
It works! If anyone wants more details let me know.
Good to be able to keep old kit going for resonable money.
I had a UQ which had a new screen display fitted.
Replaced it with Atom.
UQ is a great little device.
I’m not streaming that much, I speculate to reverse back my Atom to UQ in the office setup.
However I find the internet radio sound better on Atom vs UQ.
Maybe there’s an explanation for this ?
I listen a lot to internet radio, maybe I should just stay put.:blush:
Apart from any general improvements in the streamer, DAC or amp in the Atom over the Unitiqute, there are quite a few stations that the Atom can get in a higher quality stream format, so depending on the station you listen to, it’s very likely that the Atom will sound better.
