Hi all… I’m trying to find a source some fixings for Chrome-bumper control knobs… I’ve got the grub screws (although they look a bit on the large side, to me) but I need the threaded plate that the grub screw goes through… are these a standard part? Also are these the same between the small (NAC 32.5) and large (HiCap / 42.5) knobs?
Tim, I take it Naim’s stocks are exhausted?
You could try ringing round some dealers or try Darran at Class A who may also be able to point you to a source for the threaded plate.
Sorry, Richard, it never occurred to me that Naim would still carry this part… what’s the best way of getting in touch these days?
Best via dealer.
I think the size is 6BA x 1/4 inch grub screw. Can anyone confirm ?
Yeah, I have those, but it’s the threaded plate that they engage with that’s proving problematic…
Search for Stedall, Threaded Plate Part No. 6000585
Is this what you need. If not quite, a file to adjust?
Thanks, catswhiskers… I’ll take a gander…
I see what you did there… very droll…
Honestly, nothing more than a Google search.
For myself it would be into the shed and tipping out the odds and sods tin. When I was young anything that could not be repaired was stripped and sorted into nuts, bolts, washers etc. My grandfather had a large workshop, one wall was lined with shelves holding large Oxo tins, none labelled but they were full of treasure.
Anyhow, did you get sorted?
Sorry, I thought you were pulling my leg… that plate is 30x40x8mm with an M12 thread!!! I think I may have found a suitable threaded plate in my original, old-school SNAPS knob… (took me ages to find it)…
