Flat cap xs
Can I use a flat cap xs with a nd5xs2, is it a good pairing
No, you cannot use any external power supply with the ND5XS2.
Ok thanks
If you want power supplies on your ND5XS2, the way to do it would appear to be to add a nDac, then put power supplies such as XPS-DR on that.
