Hi,
Can you tell me if it’s possible to add a flatcap 2x to the NAC92 and run 2 NAP90 to Biamp them?
If so can you advise on what cables and connections I need to achieve this?
Frank
Hi,
Frank
Yes, no problem. You connect the Flatcap 2x to the NAC92 via SNAIC 5 (When new the FC2x would have come with a SNAIC5). Then take the pre-amp signal from out from the FC2x to each NAP90 via SNAIC4. Power out A on the FC2x provides three stereo outputs on DIN4 (Signal Out A, B & C).
Hi Richard, Thanks for the quick reply. On the back of the FC2x there are 4 plugs Power out A and 3 signal outs AB&C. Can confirm that the NAC92 connects to Power out A and the NAP’s connect to Signal out A &B. Do I remove the blanking plug in the back of the NAC92?
Thanks,
Frank
Yes, you’ll need to remove the link plug to reveal the 240 degree DIN5 for the SNAIC 5 connection.
Hi - so SNAIC plugs into the power out A and the NAP into signal A&B
Frank
Yup, just be sure the SNAICs are the right way round - banded ends closest to the source of the signal.
