Before someone kindly suggests the connection guide - which I have looked at or a search which I have done!..
Please where do I connect the din plug to a flatcap xs? - this is already connected to a CD5X and ~naitXS
I already have the correct din to phono lead which I want to use rather than using a new phono lead from the amp. I’m not sure which socket to pop it into!
There’s every chance that the pre out via the Flatcap is not optimal for use with a sub, especially with longer cables, unless you have a ‘slugged’ cable with a resistor on it for that purpose. In this case the dedicated RCA sub output on the amp may give better results. Maybe worth giving Naim a call and see what they recommend.
Naim’s sub lead, available in 5m and 10m length, used low capacitance lavender/grey interconnect cable and was “slugged”. IIRC it had a 100R resistor fitted in the DIN plug. This enabled the pre-out in the power supply to drive such a long cable without instability.
Thank you and good morning
if its using the din off the flatcap are the 2 channels merged and the resistor squeezed in or are 2 phono leads - 1 to each channel better from the XS.
On a whim I’ve decided to move the TT wall shelf ,large wall mounted CD rack and now found out I didn’t paint behind the cd rack when I last redecorated…keeps me busy I guess!
I used to run a sub from a Hicap I bought a din to 1 RCA adapter and plugged a sub lead into that worked a treat I still have if I’ll dig it out later.
