Focal Hekla Current Leakage
Hi there,
I am new to the forum so apologies if I am positing in the wrong place.
I recently bought a Focal Hekla to replace one of my beloved Naim Mu-So and upon plugging it in, I felt Hekla some current leakage (vibrating sensation if you touch the surface).
It is plugged with the 3-prong uk plug that came packaged with it, I’ve tried multiple wall outlets around the house but no difference. I was wondering if other owners had the same issue or any advice?
This is similar to other alloy cased floating mains kit such as the Naim Mu-Sos, Apple MacBook Pros etc.. According to a previous post on the subject regarding the Mu-So it’s nothing to be concerned about apparently and can often be ameliorated by switching the figure eight mains connector the other way around (it’s always worth testing this anyway as often one way will sound better than the other - at least it does with the Naim Mu-So).
Interesting! I’ve sometimes wondered why the Qb2 in the kitchen seems to vibrate when I clean it. Which isn’t often.
Tried switching the main connector but it didn’t seem to make much difference sadly. Not sure if there is a way to improved this.
My aluminium aquarium lights do this. As different lights do it, I’ve never worried about it as a fault. I’d worry if my hair stood on end though.
ATB, J
Most of my Apple kit has done this.
