Form+Klang LP12 wall shelf
I would like to ask if anyone here uses a Form+Klang Bracket LP12 wall shelf with this turntable. I would appreciate any experiences or impressions you might have. Based on the design, it should work well, but I want to avoid just drilling it into the wall to test it. Thank you in advance!
Picture Copyright (C) by Form+Klang
Never heard of it before but looks pretty neat
Possibility even more interesting is that they appear to be offering replacement foam grilles for SBLs, SL2s, Isobariks & SARAs
Though they cost as much as a used SBL/Sara/Isobarik. Well, almost.
True, but if you need grilles you’ll get them from anywhere you can.
My SBL grilles came from Markie in the West Country, but I have a feeling he has retired.
And after our Briks’ grilles disintegrated - for the second time - we opted for “cloth on a frame” jobbies (possibly from Wilmslow Audio? ….can’t remember!)
Yes I bought a pair of Wilmslow Audio replacement black grilles from them maybe 12 years ago. Used them ever since, they look the part and no foam particles falling on floor.
Martin
They appear to make an interesting looking, isobaric loaded speaker, too.
Looks remarkably like the Kan II stands.
Should sell well on their own.
Yes look very similar just the allen(?) bolt fittings for the base being different
Yes ,the Linn Kan II stand bases are welded. Kan II stands have spikes upwards against the speakers.
:+1: I changed my top spikes to allen key bolts that sit in the counter-sunk recess’s, just use small blobs of blutak now
I’ve tried that but I much prefer spikes.
