Is it me, or did the font on this forum just change?
It did. I asked Richard and apparently it’s to match the style of the website. I think it’s crap, not even proportionally spaced.
I was wondering the same, no big deal.
Yes, the font has been changed to match the website.
Request you change it back. Its CRAP.
Just thought I would give you some helpful and constructive advice
I rather like it. Easier to read on my screen anyway.
Glad of that just about to make an appointment at he Opticians??
I also thought my eyes had gone. Tiny typeface as I type.
Tiny.
Yes agree the font size ‘Normal’ is a bit too small
I’ve gone up to ‘Larger’
The revised font works better white on black, doesn’t work as well as black on white.
Some of the web-site is still on a grey background with a different font, is this available for the forum?
Much better! Thanks.
The text size selection doesn’t seem to change the Topic headings on the right side of the screen - is that a bug in the Discourse Forum framework?
I don’t like the new font at all
If anyone finds they have a white instead of grey background to the page then if you log out then back in again it will fix itself.
Is the ‘Naim Dark Theme’ now the intended over the Light or Gray?
I’ve tried them all, the Dark theme is OK, maybe its easier on the eyes, but I’m sticking with Grey
I must say I think it’s rubbish. I suspect I’m going to find I’m not on here as often now…
It’s just a font change. Nothing else has changed.
I’m going full immersion. Keep looking until I acclimatise.
Its smaller and more difficult to read. Why on earth didn’t Naim change the font on the website if they wanted to align them, rather than cripple their whole on line presence?
