Has the forum software been updated?
There used to be a “Unread” button on the top of the page – to the right of the “Categories”, “Latest”, “Top”, and “New” buttons – its been missing from my screens for a week or so.
It was the first button I would toggle to show all the unread post in followed threads.
Its absence is annoying as now I have to use “G+U” key shortcut to hopefully achieve the same thing.
I first thought it had changed because I updated my mac to OS27.2 but I see the same thing on my iPad.
Anybody else seeing this – missing the button?
Yes, it’s a forum layout change. However, you can now go to the “new” tab and just look for anything with a number after it.
Not sure if you have realised but thought I’d mention it in case you hadn’t:
If you select “New” the category is split into “Topics” and “Replies” .
Selecting “Replies” will effectively give you what “Unread” gave you.
Selecting “Topics” will give you what the old format labelled “New”
An extra key stroke but I’ve got used to it now.![]()
