I have to move my Fraim to a new location, which is ok - except that it will now be near one of my 2 SVS subs. Now, those only play when movies are on, and so the hifi is not playing - but are the vibrations not so good for the delicate Naim electronics, or is that only when trying to reproduce good sound?
I wouldn’t worry - if you’re not using the Naim kit as part of the AV setup then a bit of vibration from the Subs is not going to be a problem.
Probably just need to tighten the bolts more often as it tends to fall apart lol
