I rebuilt half my two-stack system this week, but mislaid a ball-bearing. I have looked high and low for this AWOL item to no avail. I have no sticky fingers to blame either. May I have suggestions from whence I can find a replacement? (P.S. my dealer is no longer in business)
Try tomtom audio they do mail order or give them a call
Cymbiosis on their estore has a single bearing for Ā£1.61
Tom Tom Audio Shop
Phil
Got mine from āthe bayā. I wasnt going to pay that much for a ball bearing. Got 20 SS 1/2ā for just over a fiver.
The ball bearings need to be mild steel. Stainless balls didnāt sound as good, although they are (were?) available as an option for places of high humidity.
Bought a set from my local bearing supplier ā¦took a sample one in and they matched it ā¦Ā£1 each but did feel they over charged me a little and I probably could have got a bag full cheaper if I was tradeā¦
Very interesting. Normal ball bearings are hardened cobalt steel, a very different material.
Ball Bearings are usually 52100 Ball Bearing Steel here in the States. Used to also be used for ball less gas bearings for high performance applications. Agree with Richard.
Thanks Gazza
Oops, yes I forgot we were using some rather special ball bearings!
How much is it to buy from Naim (via Dealer) ? I am curious now.
Ā£1.61 for one ball
When I get my new Fraim - Iām going to buy a bag of 10 spares! I will definitely lose some!
Hello Richard,
Can you confirm your comment about āmild steelā bearings please? I cannot find any available. I live in a high humidity environment (at the moment) and can confirm that a number of the balls have surface corrosion.
A āproper specā for the balls would be most welcome (size, material and grade) please.
Abdabs, I donāt have that info Iām afraid. IIRC, It was once posted in the old forum, so maybe worth a search in the archive, however, youāre best off contacting Naim for that info.
Thanks Richard!
