Quick question on FRAIM,
Does the original naim FRAIM come with the plastic glass locator?
Is it part of the components coz can’t see it in manual.
The plastic self-adhesive rings should come with new Fraim items.
In my experience, some stick very well to the point they can be difficult to remove and others don’t, and fall off easily.
