I have been advised to keep my phono stage and TT PS separate. If I had them together would mean one less shelf required and could change the order a bit.
How separate is separate? Mine are next to each other one one shelf, with about 4 inches between them. I’ve played with moving the tt ps around, but cannot hear any difference if its farther away.
@Bart, I have an identical system to yours with exactly the same stacking set-up on the Fraims. Only difference is Sopra-3 vs Magicos and I do not have a TT. I have had trouble keeping all the Burndys off the carpeted floor and the SL interconnect from 552 to ND555 is also on the floor (too long). How are you set regarding this ?
I have the din interconnect looped over (not coiled around) the burndy per some recommendations both here and from my dealer. Views on this vary.
My little chart didn’t show that there is an empty Fraim level on the left side. I’ve not decided whether to put the empty level above, or below, the 552.
