Hello,
I’m not sure if I’m the only one or not, but it’s been few days that France Info is not streaming well. It plays for about 5 seconds, then stops, then starts again, stops etc.
This has never been the case at all since the radio service change.
I’m on a uniti nova, and wifi.
None of my other favorite radios (including some hi def ones) is showing a similar problem.
What I’ve tried so far (unsuccessfully):
- remove the radio from favourite and preset, added it again.
- restarted my router
- restarted the nova
What I cannot test is wiring internet, but again the other radios are not showing this symptoms.
Thank you.
