I moved a while back to SuperLumina cables in my system (SL speaker cables, XLR cables to connect the NAC552PS to NAP500 and the din-RCA cable to connect the Chord Dave to my NAC)… I am wondering if the din-din interconnect which connects the NAC552 to the 552PS is also available in SL format? As far as I can see from the connection guide, this is a power-only interconnect.
I am today on the stock grey Naim din interconnect for this connection, not sure if I am missing something or not here.
Yes, that is the one I was wondering about, I marked it in the screenshot with the red outline… It is a 5pin-5pin DIN cable in 180 degree pin layout… carries only power.
Got it, thanks… nothing to worry about then… funny I asked my dealer and they believe it is available in SL, thought it was weird and wanted to check here… thanks for the reply…
A Snaic is really black, the same colour as the Burndy. It may be worth checking it’s a modern Snaic. A long time ago, the Snaics were grey and not as good.
True, it is pretty much the same color as the Burndy except for the neck which has a rubber protective sleeve of some sort that is more to the gray color than black… I guess I am safe.
