I have my Uniti Nova on a pretty cheap, and mostly empty, bookcase. Used it as I couldn’t think of anything else to put it on! Had the Atom on it beforehand.
Does it actually make any difference to it? Are certain units better than others, or it of no consequence what it is sat on?
If so, I’d love to know what others have their items on…and if there is any truth in this whatsoever!
People do say it makes a difference as to what supports your audio equipment, I’m now lucky enough to have mine on a fraimlite, I too own the Nova. Previously it was in an IKEA ‘Besta’ tall unit with a glazed door in front of the Nova. I think there was a difference in SQ but it did seem to be very subtle.
Why not take a look at the System Pics thread, and you will see exactly what people use.
The Nova may be different from the classic Naim boxes, as they are of a different construction and have different feet. Over the years I’ve heard massive differences resulting from system supports and am a firm believer in supporting the boxes as well as is practicable in order to get the best from them. Others may think it’s all snake oil and that supports make no difference.
The accepted wisdom is that it does make a difference. Although I doubt many people have done a side by side comparison between the various options.
The system pics thread shows that there is some nice non-specialist furniture you can use as well.
One obvious benefit from using a proper rack is that you can properly organise your cables. Taking care with their arrangement does make an audible difference (in my experience).
If you’ve got a relatively cheap system then it may just benefit from buying some sort of isolation platform.
Mine’s on Hutter which at one point was the forum darling before Naim launched their own
If I had just a Nova I’d use a nice side or coffee table. You can get some lovely ones from Heals and then there is Ercol and various others. Putting a sheet of glass or some such underneath the Nova may make a slight difference but would spoil the look.
I use an old Quadraspire Q4 rack with various length columns.
Looks a bit odd or weird.
I have two top loading sources (turntable and CD player), I still wish to remain my kit into one rack only.
Always lusted after a 5-tier Hutter but rarely seen these s/h.
