Furutech NCF sockets
I have managed to do a comparison with RUss Andrews Ultrasocket which is similar to my previous Supersocket but with rhodium plating and process that is exclusive to Russ Andrews.
The Furutech has more bass information and punch. I don’t want to say considerably more but I will say noticeably more. It takes all but a second to hear the difference. There is also a lot more atmospheric and treble information. Now I should also add that the Russ Andrews suits my system atm as my Dps4.1 and DSS4.1 are still going through their bright and painful stage.
But my experience with past Furutech cables is that eventually the top end is silky smooth and the power at the low end comes through.
I hope that helps.
BTW does anybody know if Furutech NCF includes cryogenic treatment.
I’ve heard cryo cables and speakers before and the Russ Andrews US definitely sounds like it’s been cryo treated. My memory of all the cryo products have been a cohesion and flow to the music.
It’s been 10 days now with everything connected to that socket through a Plixir BAC1500 MK2.
Most thing sound good but bass punch and attack is considerable less hard hitting and more in the background than a standard Busch jaeger wall socket.
Most things are better than a standard socket except punch and attack, the bass also becomes rounder. It’s a more relaxed listen, less hasty so to say. Sometimes that’s a good thing, sometimes feels like it reduced PRaT a bit. Sound is less full, highs have a lot more resolution and it’s a lot more silent with less noise. Many upsides but still some considerable downsides as well. Hopefully they will disappear. I’ll give it another 15 days and then decide whether I’ll keep them.
Yes rhodium low end grunt takes its sweet time to reveal itself. If I have the time I’ll do a comparison to a standard socket. I doubt I need to though, the Furutech NCF was more revealing across the spectrum. Including power and punch
I have a Furutech GTX-D Rhodium wall socket that I installed maybe a decade ago when I had all Naim components. All my gear was plugged into a Wiremold L10320 powerstrip terminated with Wattgate 5266i plug (same plug as a Naim Power Cord). Using mid-level gear at the time, I recall an instant positive change in the SQ primarily on mids; clarity and crispness. Better? Yes. The competition was the 99 cent run of the mill made in China wall socket that came with my then 20 yo house. If I didn’t notice a difference I’d say there was a problem. Besides costing more, quality wall sockets (hospital grade, etc.) have a much better grip and more contact area on the plug. Inserting the plug requires much more force and likely scrapes off any tarnish.
Anyone went back to standard sockets or something else than Furutech? I for a few days back changed my standard socket to Furutech Rhodium NCF which I used a couple of years ago but I’m not convinced.. Maybe it’s a mismatch between the metals in my Puritan Ultimate power cable and the Rhodium plating. Might have to go back if it doesn’t sound better next week.
I’ve had my eyes on GigaWatt SCHUKO G-044 too which use solid brass connectors so I just placed an order on it.
The solid connectors of the socket are made from brass, and their surface is protected against oxidation. Powerful contact and large connection surface of the connectors with a width of 10mm guarantee perfect connection with the plug pins. Additionally the connectors were de-magnetized. As a standard, the sockets are equipped with bolted connectors allowing the usage of large diameter cables. Mounting depth is less than 30mm. Wall mount is possible using strong expansion feet or bolts.
The internal chassis is made from hard to break, high quality, matte plastic and has a grey finish. The faceplate is made from solid, anodized aluminum, 6mm thickness. On demand we can also supply a dual version of the socket (G-044 SCHUKO Duplex), consisting of two separate inlays and a double frame, that can be mounted horizontally or vertically.
From HIFI-Advice www.
The sound became more involving by being more deliberate and better-textured. There was more “life” in the musical presentation but with a tonally full delivery.
The resolution of detail had also improved but without making the delivery analytical or introducing a feeling of artificiality.
There was definitely no edge or hardness but neither was the sound overly polished and certainly not dynamically compacted or less exciting, as can happen with certain high-end connectors and outlets. For instance, the Rhodium-plated and Gold-plated Furutech outlets that I used in the past provided a highly refined and polished sound but at the cost of a measure of propulsion, expression and dynamic impact.
Actually, the bass with the GigaWatt socket had become more incisive and impactful and the pacing more upbeat than with the standard outlet while retaining a very neutral “earthy” and sonorous quality, contrasting strongly with most Japanese specialist high-end brands.
The G-044 Schuko is a high-quality in-wall power socket with an internal chassis made for GigaWatt by German company Merten. The installation wire inlets are silver-plated. The internal contact materials are made from brass and their surface is protected against oxidation (with what seems like a Nickel-plating). A powerful contact and large connection surface with a width of 10mm guarantee a perfect connection with the schuko plug pins. Additionally, the connectors are cryogenically treated and de-magnetized. The faceplate is made from solid, anodized aluminum with a 6mm thickness.
I rate the socket as the best upgrade per spent euro in my set. It takes a while before it settles, perhaps even when it hasn’t been used for a while.
Let’s see what silver plated brass which is cryo treated + de magnetized do vs Furututech Rhodium NFC. I’ll be back.
Keep us posted.
I’m pretty sure the Gigawatt gives a bit more bite, dynamics and attack than the Furutech. The furutech brings more refinement, flow and blackness/low noise floor.
I’m trying my system into the standard Schneider electric grounded outlet now until my Gigawatt arrives. The Furutech rhodium makes my sound unbalanced. It throws out a rather artificial big sub bass which makes the presentation sound unbalanced for me. My Furutech is well burned in. Might be a mismatch of metals or just too much rhodium (I have Rhodium Furutech on IEC into my Puritan 156 and on all Powerlines Schukos. Puritan says the below. The last lines about mating galvanically is interesting.
What’s you mains cable to the Puritan?
Puritan Ultimate with original Schuko and Furutech Rhodium IEC.
Before you make your final decisions to the wall socket I would to replace the Schuko for a fi-e50 NCF connector. This connector makes a a huge difference and is viewed by many as the reference connector in the business. Then you have perfect matched plating throughout the chain.
On top of that it also reduces bloated bass response. Takes about a month to burn in though.
Gigawatt is here. Will try to put it in during the week.
I’ve wondered about this as well. I quietly added a FI-28M (G) Wall Plug for my Farad Super3 powercord. It made a nice difference compared to the Wattgate. Just an experiment trying “Gold” instead of more Rhodium.
I tried gold Furutech on a Puritan Ultimate to my 156 but the bass got too bloated. Fascinating how a single connector can change the audio spectrum so much.
Agreed on how a single connector and change things. At first I thought the (g) was too bloated/warm in the bass until I sorted out a network issue which I didn’t realize I had. Now I don’t even think about that connector.
Gigawatt socket installed and again it’s and eye opener (ear) in how much difference a wall socket make. The giga sound a bit cold and analytical with slim bass but it’s only 5h in. I know the same thing happened with Furutech rhodium which took atleast 300+ hours to settle.
