That keeps the bird watching down to just one bird for a while.
I hope so Gazza weâre overwhelmed with pigeons at the moment.
The Gatemen comethâŚ
Meanwhile, Disa checks out the secret side cat entrance.
I canât wait to brush on the wood stain, but as soon as the guys finished and left it started drizzling and hasnât stopped since
Very nice.
Wood stain? Nooooooooooooooooooooo!
Yeeeeeeeeeeeeeeeeeeeeeeeeeees!
Itâs only knotty-pine so Jacobean Walnut here it comes
Debs, it may be just pine (nothing wrong with that), but I would stain it first, then look after it using Roxil decking oil. Using a wood stain finish is the worst way to begin and look after any wood. It will look horrible and get worse.
I like the design of those gates @Debs !
Is this why you played Relayer featuring The Gates of Delirium today?
I could answer that with a Roger Dean art font
Finally got our âgateâ fitted this a.m. - overdue from late DecemberâŚ
it is rustic, very sturdy, well built, and was fitted with careâŚ
Pleased with itâŚ
Thanks for the advice, the Sadolin is okay, it is an excellent wood preservative that penetrates deep into untreated softwood, however it does tend to colour dominate over the grain so iâve had a re-think and decided to use what the gate maker recommended but in the âlight brownâ which should protect well but leave the woodgrain enhanced.
This will probably go on tomorrow - weather permitting.
Look forward to seeing the end result.
We use Barrenttine clear preserver on all our outdoor wood itemsâŚshed/furniture/gates, etc. Brilliant stuff, came highly recommended by the. Guy who supplied our last shed.
Hi Debs, the Sadolin is basically an all in one coating, like a lot of the other exterior wood finishes. Itâs basically a varnish, so doesnât penetrate the wood much, even thought the sales literature says so. The problems with a stained varnish are 1) as soon as you apply subsequent coats, the stain becomes more and more opaque and youâll have a painted brown gate with no grain. 2) In most of these stained finishes, they use paint pigment to achieve a uv protection, so you are painting the gate brown and not staining the lovely naturally wood grain.
IME, the exterior wood starts to go downhill within 12 months due to mold, algae and flaking. If you treat the wood with a good clear preserver first, then stain with pure wood stain, then look after the surface with a decking oil containing biocide, it gives the best long term results and looks the best right off.
I used a Barrettine decking oil last year on a project which contained a biocide, but within 4 months small amounts of black mold started to appear . So disappointed.
Itâs not really gardening but the garden house now has preparations for floor heating & concrete floor fitted
That looks a wonderful space.
Before and after on the gate progress:
After the 1st coat of Barrettine âlight brownâ wood preservative:
Looks very nice.
