Not sure if this is the right place but…I would like to connect my Astell and Kern AK47 to my system.
Is this possible and what do i need to do this with incurring too much expense…the lockdown has stopped all and any cashflow!
Thanks for you help.
A bit of info on the system you want to connect it to would be good
Durrrr…yes sorry about that!
82/2xHiCap/250/SBL.
You’ll just need a stereo 3.5mm to 5 pin (180 degree) DIN cable to connect to one of the spare inputs on the 82. Here is one i use to connect my Sony 1Z player to my Nait 1.
Flashback cables will be able to sort you out - that’s who did mine and will ensure it’s wired correctly for a Naim input socket.
Perfect…thanks!
Just ordered one!
