Good Kettles?
Any thoughts on kettles? Particularly maybe ones to avoid.
Was going to post in The Best thread but not necessarily looking for very stylish/expensive.
I’ve always been reluctant to spend a huge amount on a kettle but it’s generally been around £30-40 pounds which I appreciate may not be much - generally more interested in something that works well, is ergonomic for me rather than more expensive ‘designer’ ranges.
Used to love a certain Philips kettle and probably got 2, maybe 3 over many years:
Looks like I last purchased it on Amazon around 12 years ago but it’s no longer made and when that failed I tried a stainless steel one probably from Russell Hobbs which imparted an awful taste on the boiled water I could not tolerate so back it went.
Then bought a cheap Breville in Tesco which despite being plastic was very good - now on a second one of those which may be about to fail (was there a slight leak yesterday when I used it?Mrs AC thought it had failed to turn off during one use and probably did when I boiled it this morning).
We’ll all have different preferences in terms of style/ergonomics/colours but ideally I’d want mostly in order of preference:
  • one which imparts no odd plastic/metallic tastes to the water
  • rapid boiling so probably 3 kW
  • good pourer
  • 1.7 litre
  • cylindrical design rather than traditional broader base for counter space
  • easy to fill without physically removing a lid
In recent years I’ve wondered about some of the variable temperature ones or more expensive kettles, mainly as I drink far more fruity/herbal infusions and non-black teas than years ago.
Have looked at numerous online reviews this morning and as with all such things many have negative comments but with several the same flaws are mentioned.
Variable temperature Sage one seems to have many complaints about the glass in the lid cracking causing failure and apparently it’s dropped from a 3 kW to 2.4 kW element.
Variable temperature Ninja has reports of early failure/control panel failures and it making loud often pointless beeps - something I really dislike about our Ninja Air Fryer.
Can’t find the current Breville one we have - style seems to have changed slightly but many users now reporting poorer quality/cheaper build and chemical taste to the water.
As kettles generally do fail after a few years it’s probably why I’ve not purchased very expensive ones and several more expensive ones don’t seem to last long either.
I haven’t read all your criteria, apologies.
FWIW, I have a Dualit double insulated thing. At £165 (!) it’s the priciest by a margin but nothing comes close for ease of use, looks (to these eyes) and how quiet it is in use. Highly recommended if you can stump up the cash.
Last time we needed a new kettle, I got a £30(ish) John Lewis job that lasted about a fortnight before the lid closing mechanism broke completely. Probably could have returned it, but in a bit of a fit of pique, I went for Dualit’s cheapest:
Several years and a house move later, it’s still going strong. Yet another slightly irritating example of getting what you pay for.
We have very hard water and I like my ‘proper’ Assam and Darjeeling, so we use a Brita jug religiously. The kettle still needs descaling every so often, but it’s not too bad.
Looks nice. I may have had a quick peek at that earlier online, and presumably being Dualit there are good repair options available.
In reality I dont think anyone can give you advice on what is a good build, but they certainly can say what is bad. The problem with someone recommending their brilliant 15 year old kettle is that it’s very unlikely that the latest iteration of that kettle will bear any resemblance of build/parts quality to its 15 year old predecessor.
I have two criteria when buying a kettle
  1. 2KW minimum for a quick boil
  2. A true 1 cup minimum fill (probably more important)
Yes, I think that’s potentially what I’m looking for, hence my query on poor experiences/ones to avoid.
Sadly I just get the impression from many online reviews that spending a fair amount above a basic device does not necessarily get you a good build/quality materials or product longevity or do we just accept that’s the case for most things these days?
If the current Breville was available I’d probably get one (I had a look a while back considering getting one as a backup but couldn’t find any) - decent and cheap enough to replace every 3-4 years if you had to (not that that’s ideal ecologically of course).
While tempted by a variable temperature kettle it’s just another bit of the device which might play up or fail.
For a £35 kettle, take off the vat, transport costs from manufacturer-importer-retailer-consumer, retailer markup, manufacturer markup, etc… and you’ll be left with about a £5 product. Anything plastic will crack, scratch and retain odour.
Best of luck getting a safe rapid 3kw kettle that is designed well :rofl:
I don’t consider 2kW enough for a quick boil! I always specify 3kW, though I note that our current kettle, although bought as a 3kW is actually rated 2.5-3 kW, though I’m not certain what that means in practice - I assume 3 kW at the highest end of permissible voltage range.
We’ve had our current kettle for 5 1/2 years, avoiding typically 1 L of water 6-8 times a day probably 300 days a year.. No problems with it at all so far, although the volume markings on one side have partially faded – oddly the other side hasn’t and that’s the side that mostly faced the window! Clear glass with good visibility, 1.7 L stated maximum capacity. Minimum level is ~200-250mL, nominally one cup. A blue light illuminates the contents when switched on. And it is a straightforward turn off automatically when it boils.I wouldn’t buy one of those complicated ones that keeps the water hot, or stops at other specified temperatures etc.
It’s a Russell Hobbs, bought for £35 in April 2021. Hopefully it will carry on for quite some years to come, but obviously I don’t know how long it actually will last.
Yes, I get your point. :wink:
Hence the post really, I’d not be surprised if there are models I know very little about as I’d always just felt ‘they all just boil water’ and many can seem very expensive if you’re not too bothered about getting something stylish/designer.
Some of us probably treat kettles like light bulbs! Once they fail it’s often a necessity to replace fairly quickly from the viewpoint of practicality if you don’t have a backup to use immediately - easier for bulbs due to less storage space needed. Even a replacement purchased temporarily might stay for years as if it works and is ok I decide not to change it.
I’ve always avoided SMEG simply as the acronym makes me think of Mycobacterium smegmatis :rofl: :man_facepalming:
Earlier found and really like the look of their variable temp model at around £190 and thought that might be good, but several reviews I’ve looked at on a site suggest the paint starts cracking ruining the finish. Maybe a batch issue.
Anyhow, what would you suggest?
Thanks, I’ve also wondered about clear glass ones as I’d assume far less risk of tainted water taste from the metal or plastic used in most.
Anyone know why some metal kettles impart an awful taste which does not go away over time.
Plastic can’t be perfect either as I’d assume microplastics of some kind potentially including forever chemicals must get into the water.
Never mind the kettle what plug do you change to after chopping off the moulded one. :wink:
We tried a Dualit one:
Really a commercial grade one which was very well made and sturdy but we found it heavy and cumbersome. Cost £76.
Now use this:
Igenix plastic one. Far nicer to use, works just as well, cost £22.
Oooh, please elaborate? Have you had issues with moulded plugs? I would assume they are better than I could do, not having a crimping tool.
If you have one of those kettles that whistles then I would advocate replacing the moulded plug with an MK. You will get much improved pitch definition from the whistle.
Ergonomics and weight can be very important for so many household items especially as people get much older (thinking of mother in law who was struggling with a kettle a while back).
This is why I’ve never spent loads on kettles - expensive and cheap ones still boil water as there’s not really much to that. I vaguely recall electric kettles we had when I was a kid which would boil until switched off manually.
The more functions added simply increase things in teh product which can fail.
It was a bit tounge in cheek but I’m surprised considering some up to 3K power have such puny plugs on them.
I don’t like moulded plugs. :scream:
As long as the cable is at least 1.2mm and the Bussman fuse is the right way round sorted. :dashing_away:
Exactly that. This is now a primary consideration for anything we buy for our home.
That was my assumption :wink:
Perhaps there should be a thread analysing how actual plugs on domestic appliances might affect our hi-fi audio quality.
@Alley_Cat
I reckon any plug that doesn’t run the risk of being dodgy must improve the sound quality in a house that’s not been overheated. :fire:
Me neither. I always feel a compulsion to cut them off and fit an MK safety plug or a Permaplug. I’m not sure it really achieves much, if anything, in the context of a kettle or vacuum cleaner etc. but it makes me happier. As we haven’t got a dedicated mains for the hi-fi I’ve replaced all plugs on the ring with MK Toughplugs. I’m not sure if it really affects the sound but some of the plugs previoiusly had nickel plated pins which I didn’t think would be good.
