Ground or Floating
I am just about to connect a n Audiolab 6000cdp cd transport to my Unitilite.
I will be using a digital coaxial cable to provide the signal.
The Audiolab is grounded so should I set the switch on the Unitilite to ground or floating
I’d leave it at chassis.
Very easy to decide by ears. Listen 30 seconds with ground, then switch to earth, then choose the best.
Be sure to keep a good floating distance and notably in a floor squatting position to recover safer ground instantaneously if after 30 seconds it blows up.
