Grounding RP3 to Supernait3
Hello all
do you connect your TT ground to your Naim gears?
I have Rega P3 and Supernait3.
If so, how do you do on the TT side? on the integrated amp, I found the ground connector, but not on the TT.
thank you
If there is no ground wire, dont worry.
Yes. There is a Ground lead from my Linn Ittok, which is connected to my 82’s Ground terminal, adjacent to the Phono inputs.
The Rega is grounded via the two phono plugs and does not have a separate ground lead. No need to worry.
thank you!
IIRC Rega turntables don’t use a separate ground wire - they ground via the left channel of the interconnect instead. Rega argue that this sounds better.
Thank you
