GURU 8 + Naim
Hello to all fans of the GURU speaker and Naim electronics combination.
A few days ago, I bought a pair of GURU 8 speakers (replacing my KEF LS50 Metas). They are currently still in the break-in phase (or so I hope). Since they haven’t yet lived up to my high expectations, I’m wondering if anyone has experience with the combination of a Naim Uniti Atom HE (used as a preamplifier) ​​and GURU 8 speakers (powered by an Apollon Hypex Ncore Class D power amplifier). My setup is in a rather unconventional space. The entire area is open-plan and approximately 50 m², though the specific listening area covers just under 20 m². I’m wondering now: could the GURU 8 be a poor choice for such a large space?
That said, the speakers do seem to have potential… The KEF LS50s were perfectly decent speakers, but they never truly “breathed”—I felt they lacked airiness and a sense of ease.
I would greatly appreciate any sound advice regarding the GURU 8s—especially concerning room size.
I am assuming you did not demo at home (or the dealer) with your components?
Describe what you are hearing and what you were hoping for. First thoughts are that you definitely do need to loosen up new speakers before making further changes or spending more money. This can take a while, maybe 100’s of hours with some designs. I’d then look at simple cost-free changes like positioning, toe-in etc so you properly explore the system you have built. Are they on the manufacturer stands?
I don’t know your amp or the speakers personally but that is a large room. However don’t give up yet unless you have an option to return them that is going to expire which might need a decision soon. Do the simple things, and be patient too.
Bruce
It’s true, I didn’t test the speakers in my own room or with my own electronics. Sometimes I’m a bit too impulsive… but I had heard GURU speakers before, and I really liked their sense of ease—something I felt was missing with the KEFs. That’s why I decided to make the switch. As soon as I hooked them up at home, I was surprised by how shallow the sound was and how small the soundstage seemed. In short, the performance was lackluster. I positioned the speakers according to the manufacturer’s instructions (I’ve attached a photo).
What I’ve noticed is that, at times, they start to come alive and draw me in to listen… but then, nothing. They probably just need time. At least, I hope so. Still, I think there’s potential for them to sound the way I’d hoped. On the other hand, I am a bit concerned about the size of the room, though it’s hard to judge exactly what counts as “listening room size.”
Yes, of course; I designed the stands myself, based on the height of the shelving unit. The base is made of granite and steel tubing.
Welcome to the forum!
Looks a very nice setup. I’ve got both the LS50 Metas and two pairs of Guru’s, the QM10’s and the 12’s, the sound you are describing definitely doesn’t sound like a typical Guru experience, but equally you didn’t seem to gel with the Kef’s either.
I’m not familiar with your power amp, have you ever managed to get it to sound as you would like with any speakers previously?
Near Field as you are set up for TV should be fine. My QM10 did not excel filling the big sitting room at previous house. In new smaller room sublime. Time is your friend
Nice looking set-up. However, the speaker to stand interface can make or break a speakers sound. I’m not saying that’s what you’ve done but I’d maybe worth going back to basics. Try removing the stands and just using some blu-tack in each corner and then try the speakers in different positions on your unit to see if it makes any difference?
I once used some rather flimsy wall brackets on a pair of speakers of similar size. The speakers wobbled all over the place when tapped and I thought it would be a complete waste of time. It turned out that they sounded absolutely stunning on the wall brackets, so you can never be sure what will and won’t work!
I nearly posted something similar myself, the Guru’s are a pretty forgiving design (much more so than any Kef I’ve encountered) so would start with @Geko’s advice and see if the sound fundamentally changes minus the stands to start with.
Guru’s should produce a large ball of sound with plenty of height and with excellent timing and throw an image well clear of the speaker enclosures.
Before getting the Apollon, I had the Naim Atom HDMI, but it seemed to struggle to drive the speakers. I decided to switch to the Naim Atom HE as a preamp and chose the Apollon (380W/8Ω, 600W/4Ω) as the power amp. Basically, it was fine, and the KEFs were under control. But—there’s always a “but”—I felt it lacked a sense of airiness… I had actually been considering the KEF R3 Meta, but an intuition led me to GURU… and here I am.
I’ve also got the R3 Metas and they are on the sidelines because my Guru QM10’s sound so much more cohesive than them on a Naim SN3/HCDR. R3 metas sound very different to LS50 metas.
Try messing with the positions as per Geko.
The only amp I’ve found that didn’t play to the Guru’s strengths is my Technics SUg700M2, which is a pure digital amp. My Densen, Naim and Musical Fidelity amps all enabled the Guru’s to shine, Naim the most.
I could try it without the stands, but then the tweeter height would be significantly too low, don’t you think? The speakers do have standard foam or rubber pads that create very solid contact with the stand’s top plate, and the stands themselves are quite heavy and rigid. Still, I’ll give it a try without the stands.
Just worth a go for the process of elimination, the little feet on the speakers are an integrated part of the design.
And I know it’s unlikely but I once managed to connect up a pair of speakers out of phase when I thought I could never fall foul of such a mistake, just be worth a check on that front.
Really? It’s possible the Class D output stage is a factor. I hope not, though, because I read in a review that GURU speakers sound great regardless of the amplifier stage used.
Regarding the KEF R3 Meta—in what way do they sound so different from the LS50? That actually surprised me a bit.
Yes…
They might come from the same manufacturer but one is a three way design (R3) and the other two way, but with the tweeter in the middle of the mid bass unit.
So the LS50 when it really sings has a stunning coherence and is in my experience a “darker” sounding speaker. There is a American reviewer who has a whole article on how the LS50 doesn’t have a highlighted top end like many other competitors. The R3 instantly sounds a much brighter speaker but one that can sound less “as one” as a dialled in LS50. In a big room with more distance from the speaker I imagine this is less pronounced on the R3 meta.
The Technics isn’t a class D, its a bit of a unique one there (like its big brother the G1000), but instead is pure digital, I don’t profess to know or understand the intricacies but there is enough published on it that illustrates the design differences.
Didn’t want to point the finger at the amp as I have no experience of it, its just that you said that you’ve found both speakers, which can sound stunning, lacking so just wondered if there’s ever been a speaker in this setup that did sound how you like it.
Erik (Guru owner) uses Naim all in one unit as his typical testing amp BTW. They are always an easy load on an amp but they definitely will show the differences of amp designs.
To be fair re stands. The Guru stand for the 8 is an aluminium flat plate on wood. So your are not radically different but worth a play. Must say when I bought the QM10 stands they made little difference to sound but gave me back sideboard real estate.
I’m not suggesting that it’s a permanent solution. It’s just to check if they are being affected by the stands.
If it makes no difference then I’d perhaps look at the power amp?
Thanks for the comments. I’ve lowered the speaker placement by 12 cm (they are now at a height of 52 cm, which is supposed to be the height of the original stands for the GURU 8). Although I’m seeing two different figures—52 cm and 56 cm—I wonder what the actual stand height is; does anyone happen to have them at home and know for sure?
I’ve moved the speakers to within 3 cm of the rear wall, and in my experience, this yields the best results for both the bass and the overall frequency spectrum. The speakers have been playing continuously for 100 hours now… and I can say that the sound (along with all the settings) has changed completely. It’s almost unbelievable. The music just flows, and I can’t seem to stop listening. True, there’s no “UAV effect” to speak of, but I couldn’t care less, because the sound is now effortless and easy to listen to. I’ll share more observations in the coming days… hopefully still in a positive direction.
