Hana Red & SuperLine
Does anyone have experience in selecting the correct plug(s) for a SuperLine when using a Hana Red cartridge?
I’m trading in my ML and getting the Red next week but can’t find any info on the right plug to use.
Mark
The Red’s coil impedance is specified at 6 ohms so I would suggest starting out with the 100 ohm plug, which would in theory be the best match. You can then try others to experiment - all part of the fun!
I have both and initially preferred the 100 ohm after using the but found the 220 to be much superior.
Thanks very much everyone.
I can’t figure out how to update my system which has changed a lot.
I’ll keep trying!
Mark
If you mean updating your profile then go to Preferences.
