Evening all. This has come up before but I can’t seem to access the old forum pages to get to it. I need to reconnect my remote to the HDX. I used to have the key button sequence to do this but I haven’t got it written down anywhere now. Any help would be gratefully received.
Here ya go, the HDX manual, which I’m presuming covers the remote.
Unfortunately, when I had this problem years back. The answer wasn’t in the manual. I’ll check again to see if it’s been revised. Shame the old forums are not available to search as yet. They really were an invaluable tool.
Hi @Nagual, searching for HDX remote on the archive found this, and a reply from you. https://forums.naimaudio.com/topic.php?oid=21277303072870043&coid=159503632588889
The search looks in subject, so a search with limited terms can find helpful threads sometimes.
Ah fantastic. Thank you. That’s what I was looking for and couldn’t find. You’re a lifesaver cheers
