@davidhendon, @Adam.Zielinski, @garyi,
I’ve checked and the Talk Talk router has DHCP enabled.
What I can’t find, on n-Serve (on a MacBook Pro, and in maintenance mode), is where I can change the settings for both the HDX and Unitiserve.
As has been said elsewhere, I’m a bear of very little brain, where computery network things are concerned, so be gentle with me.
garyi
22
In both cases you need naims IP tool. And windows to run it…
It assumes they are fixed your router should be able to confirm this or download Net Analyzer for iphone and scan your network.
system
Closed
23
