Hi all,
I have a bare HDX that I have just bought a 555PS for ( I am going to change the HDX for an ND so only a temp step for now).
I have connected the power cable to the power supply and the burndy from output 1 to the HDX.
When I power everything up the power supply is live, the Naim logo on the HDX comes on but the screen does not and I can’t use it.
Do I still need another power cable direct to the HDX ? I thought I read if having a separate power supply to not connect power to the source as well. I don’t want to plug anything directly into the HDX in case I xxxx it up.
Help please !
Mark.
