I have a Nait XS2, FlatCap XS, StageLine S and HeadLine 2 in my system. For the last year I’ve been using the FC to power the Nait and HeadLine with power to the StageLine coming from the Nait. I recently came to the conclusion that I’m getting more benefit out of using the FC to power StageLine than using it to power my HeadLine which has pulled the later component out of the system.
I enjoy the HeadLine and I’m trying to sort out a new power supply. I appreciate that the majority of forum members will advise that I should get a HiCap DR to power the Nait but it’s out of budget (for now!) so I’m curious what members would think of using a NAPSC vs a second FC XS.
Alternatively I could abandon the HeadLine but I do enjoy it as an upgrade to the Nait’s headphone amp. Thanks in advance for any advice!
Dear Adikt
Everyone knows on the forum that the minimum to get a headline2 really singing is a supercap2 DR. Personally I have a Hicap2 non DR and it sounds excellent to me. I’ve never heard it with other supplies apart from the powered aux 2 socket of the 252 which sounds very good. I would go for a secondhand no DR Hicap if you can
I’m sure it does and the advantage of a NAPSC is that they look the same with it being a natural partner. Hicap and Supercap are an overkill but it does sound good though
Depends on your headphones. The FC delivers higher voltage than a NAPSC. I’d exoect the FC to far outperform the NAPSC. When I used a HL2, the NAPSC sounded fine but not really enough with my Sennheiser HD800. The HCdr was miles better and not just in finesse but drive. I sespect the 3v difference accounts for a lot.
My headphones are modest, a set of Focal Elex’s from Massdrop which are basically Elex’s with some Clear bits. I don’t have a lot of experience with other “hifi” headphones (I’ve owned a couple sets of Grado’s) but I believe they’re relatively easy to drive.
Thanks for mentioning the HL2, I edited my initial post to include that detail.
The fact that it’s the same form factor as my HL2 and StageLine is a consideration for me given that space on my rack is at a premium and I could fit all three on one shelf.
It depends on how much you use headphones and how much money you have spare! I’m sure the better PS will be a step up but for my needs a NAPSC with the HL2 is really great. Try that first?
My apologies for the lack of clarity, it was a long day and there may have been some whisky involved.
To rephrase my OP, at the moment I have no way to power my HL 2 and I was asking if members would recommend a NAPSC or skip it and use a second FC XS in my system. I have no experience with the NAPSC to draw on and wasn’t sure what forum members thought of it. I also acknowledged that the most popular opinion would be skip the FC all together and add a HC DR to my system which I think is out of budget.
FWIW, I was doing some research last night and on the used market here, a FC XS is approximately 2x the cost of a NAPSC and a HC DR is 3-4x the cost.
My listening habits tend to change with the seasons. In the summer I’m outside a lot more and and my listening tends to be later in the day on headphones when the families winding down/sleeping. In the winter my listening time moves forward in the day and the headphones get used less.
Based on the feedback I think I’ll try to find a NAPSC.
