Hi, which would be the best DIN to run a
HP amp from…the Hdd or the A/V?
I assume the out line level signal is constant regardless of which input is selected?
I have Nait XS2
I have Nait XS2
They’re both line In/Outs and should be the same level - only thing is you can configure A/V for Unity gain. As such, I’d probably choose HDD.
Grateful Richard
Could i use a 5 din to 4 rca in the hdd socket…the two outs to the hp amp and the ins from my Phono stage?
Yup, sounds ideal.
