Headphone cable
So, I’ve a pair of Focal Elegia headphones which I’m really pleased with. My only criticism is that the cable supplied is a bit short (less than 1m) does anyone have suggestions for a decent replacement that’s about 2m with a budget up to £300
Futureshop UK can make up headphone cables from many brands like Chord and Atlas to many headphones of many lengths.
I can’t comment on whuch brand has known synergy with your cans though. I quite like the Furutech ADL cable on my HD-600 but that’s a totally different headphone.
Cxnnected make very nice replacement cables.
You can choose the types of connectors and cable colour.
Had mine a while now for my Focal Elears and very pleased with it. Also much lighter in weight than the stock cable which is an additional bonus.
DG…
+1 here. I have a couple of their cables for my Focal Clear MG and Focal Celestee cans. Very good.
Had a longer cable made by Custom Cans for my Focal headphones very good quality and a wide range of options.
Thanks all, I’ve ordered a 2.5m cable from Cxnnected, should arrive early next week :slight_smile:
Bit late to this thread. I used Cosmic Cables, provided a good quality and fast service.
Custom cans 100%
Agree custon cans. Alrhough my last cables had to be reworked. They messed up the colours if the cables i asked for. The first ( wring) cables arrived 3 days after the order. The reworked ( correct) ones took a further 3 weeks. And i have learnt to order longer lengths rather than what i think i want.
