Hi all
Can anyone recommend a good desktop headphone stand?
It would be used by Focal Stellias.
Steve
Hi all
Steve
That’s…err…distinctive!!
Focal’s own stand is stylish and beautifully made
https://www.focal.com/en/headphones-0/headphones/cables-and-accessories/high-fidelity-headphones-stand
Very nice. Might be a little more than I can justify spending but I’ll bear it in mind. Thanks.
Tell us your budget and we can go from there.
Flexible. Just trying to get some ideas as it’s something I’ve never really looked at before. I must admit to a slight initial shock seeing the price of the Focal one (£249) but I haven’t completely ruled it out.
I don’t think I’d spend more than the £249 Focal one though.
Nice. Yes you can get some good stuff on Etsy. I got some really nice coat hooks, a shoe rack and vinyl mat for my kitchen. All very distinctive designs and well made for reasonable money.
OneGenug. 32 euros.
That is hideous, FR.
You must be a Google Jedi…
If you can imagine it, Google will find it.
I have a knife block made by the same person, it has exactly the right slots, because I told him what I wanted. Etsy can be good when you find a craftsman rather than just a reseller.
Another vote for the Rooms.
I had standard plywood omega shape stand, as already shown on this thread, and after just a couple months, the constant light pressure on the pads caused them to deform a bit.
Convinced that a good stand should only support the headband and nothing else. And the Rooms comes in a huge range of materials. Same design available in both wood or various metals. Brilliantly engineered.
I know, hideous indeed, it was a joke
If your rack is next to your listening seat a simple hook, clamped to (in this case a Fraimlite) works wonders. Inexpensive from that well known on-line shopping site. Just a thought.
A perfectly reasonable thought. I have a similar hook for my computer headset under my work desk which cost £7 and works fine.
I think I prefer the stand idea for my lounge though.
That clamp bracket is the perfect solution I need for mounting a little PSU behind my rack.
Now ordered
