Is there a funktion that lets you switch between the different headphone outputs?
I have Meze Empyrean and Focal Clear and would like of possible to have both Connected.
/Tommy
/Tommy
No all headphones are powered at the same time. But you can connect both at the same time without any problems.
It is said for best performance to connect one at a time but I’ve had my two different Focals connected a few times and there was no noticeable change.
Ok, thanks
I suspected that,
You can switch off the phones connected to the back, but not the ones at the front.
